rusted pulleys
brian102
the crank pulley is rusted really bad, sharp edges lots ofpitting, is there any cleaning to this or do i just order new ones? didnt know if sand blasting would help that enough?
Don S
Re: rusted pulleys
If they are that far gone, just replace them. Sand blasting only blows the rust out of the pits and it's still rough like sandpaper and will eat up the belts.
After you replace the pulley, you better find a way of keeping it dry or the new one will soon be like your old one.
brian102
Re: rusted pulleys
yeah the boat sunk last year and sat in water for 3 or 4 days, soon as that happend the pulleys rusted in a hurry, sucks because the motor never had a spot of rust on it, now it has a little rust and belt shavings all over it! it tore the alternator belt up and shavings went everywhere
brian102
Re: rusted pulleys
wheres a good place to order new ones of these?theres numbers on the back of them, if i google them they come up to like 68 corvettes and camaro with short water pump. its an 89 4.3 omc motor
Don S
Re: rusted pulleys
If they have a GM number on them, it's a GM part. Cheaper than adding another markup to get OEM from BRP.
aktrucker
Re: rusted pulleys
I pull my pulleys every spring and use the wire wheel on them and then paint them......I know it would be expensive, but I wish someone would make some stainless pulleys.......
brian102
Re: rusted pulleys
ok crank pulley says 3744043 then gm underneath..983839on ps and3927796 on water pump... im sure ill get bashed for this but i work for autozone and we can order pulleys that look just like those from spectre. would that be ok or should i head to the gm dealer?
Don S
Re: rusted pulleys
That is not a part that HAS to be marine. It's electrical, fuel, and cooling system parts, along with things like cams and core plugs that makes a marine engine a marine engine. Not pulleys.
brian102
Re: rusted pulleys
when the book talks about long water pumps and short water pumps it will make a difference on all the pulleys though?
Don S
Re: rusted pulleys
Not sure what your problem is with it, If the GM part numbers match, it's the same part.
