Rusted timing pointer, 3.0 LX WHERE IS TDC?
KevinKay
My pointer is all rusted out, I can't match it up to the repair manual diagram-it has 5 points, mine looks to have 6 points. You cant buy just the pointer-its part of the timing cover. Can ayone get me to TDC from my photo-I plan to drill a scribe into the block in preporation of the tab falling completely off.
THANKS!
EDIT Picture WAY too big, changed to link. Please keep pictures to 640 pix max width. or post as a link
http://img443.imageshack.us/img443/3731/pointer006.jpg
atomb
Re: Rusted timing pointer, 3.0 LX WHERE IS TDC?
The third tooth from the bottom of the tab is TDC 0 i believe.
12 < before
0 <
< after
6 <
Thats the picture on the manual you can download the manula it is one the first threads in the forum
Just went thru this with mine do yourself a favor and just buy the oem timing cover tin -your going to be leaking from their one of these days soon.
KevinKay
Yes, I found the diagram your talking about, but it does'nt match the tab thats on my boat, there are less points, plus a deeper vally that represents TDO.
image.php
[/url][/IMG]
atomb
no mthats not the same diagram thats in the manual i saw that someone posted as well that ain it.... The i counted your teeth and you have 6 .if you start from the top the the fisrt tooth is 12 and the fourth fourth tooth is O TDC
KevinKay
I am confused........its the same 5 pointed diagram in the service man. Zero in the vally, page 182
mine has six points no deep vally???
atomb
maybe this will help
Ayuh,...Did you even try to Clean the tab,... In the picture, it looks nearly Untouched...
It also looks like the Zero is in the 2nd valley north...
You can always pull #1 sparkplug, turn the motor,+ feel for #1 to come TDC...
course, havin' the valve cover off to see the valves helps, less you be 1 turn Off...
atomb posted while I was peckin',... There's yer Answer...
atomb
image.php
[/url][/IMG]
This is not what i was talking about page 102 manual 13 wll show you the same one you have
fishinpa
In any case a new timing cover looks like it may not be a bad idea anyhow !:eek:
fish
KevinKay
ATOMB, THANK YOU!
In my defence I was looking at the diagram in the ignition system.
also, I had tried to clean it up, but its un-readable
THANKS VERY much!
atomb
no sweat ,Im the same way and often not sure even when i get the correct info -Im always bothering the guys around here , Its a great forum lots of good peeps
Don S
Here is how your timing mark is marked under all the rust.
attachment.php
You will find this picture on page 3A-12 of manual 13. Under Valve adjustment.
Merc doesn't always use EXACT pictures in their manuals.
Valve layout and adjustment on some big blocks are shown using drawings of a small block.
