Rusty gas tank
maproy99
One of the gas tanks on my boat had rusted up inside to the point it began seeping gas out. Is there any treatment I can have done to the tank to fix this?
oops!
Re: Rusty gas tank
there is a gas tank repair.....but it needs the tank to come out to be done properly.
after the tank is out...you may as well replace it
airshot
Re: Rusty gas tank
There are many coatings that can be used in fuel tanks, however a boat is one place I would not use them. The risk of a leak is far to great. Getting them replaced is by far the safest fix.
Todays plastic tanks must pass tests that are more strict than for metal tanks. I have been involved in that industry for some years and if you see the tests for the different materials you will want either a plastic or aluminium tank. Testing on steel tanks are the least ridged of all the materials. Best of luck to you.
Airshot
maproy99
Re: Rusty gas tank
Ok, I found the tank I want to use, what about the fuel sender? How does the match up with the gauge work? I know the old tank didn't work, but I tested the gauge and it worked, but will the sender be different?
ezmobee
Re: Rusty gas tank
Senders are USUALLY standard.
maproy99
Re: Rusty gas tank
Even though the other tank is from 1975?
