timharper89
Thread starter- Joined
- Jun 24, 2018
- 277
I have a 97 rinker 232 with a 7.4 bravo 3 merc. I bought it late in the season last year and being honest I was lazy and didn't pull the drive last year during winterizing. I only put about 10 hours on it this year. I had intermittent growling with sharp turns under heavy load a few times when pulling tubes and whipping them around.
When I pulled the drive today I found a decent amount of rust on the u joints. Gimbal is very smooth running and the u joints are also smooth, and everything is well greased. There is no water in the bellows but obviously there is rust, so water is coming from somewhere. The bellows appear to be in good shape with no obvious cracking, though it is admittedly difficult to inspect . There is no drive oil in the bellows. Just wondering what the possibilities for water intrusion are and what i need to fix. U joints and gimbal replaced? Is there supposed to be an o ring where the drive inserts into the housing around the bellows? There was not one when I removed the drive. My alpha one used to have one.
I also found three metal plates of some sort loose in the drive when I removed it. Anyone know what they are supposed to be for?
I will attach pictures
