GT Greg
Thread starter- Joined
- Jul 19, 2013
- 18
Well my Johnny was due for an impeller. The old one was shot, as you can see in the pic I took after switching it out.
The new one seemed to go in fine. It seemed a bit tight (turning the driveshaft by hand), but I figured that was normal.
Refilled the LU, fired her up. No hot water return at first, but after warm-up it began to discharge . . . it felt a bit hotter than 145F. Also small bits of black rubber ejected, and the LU casing began to get hot . . . what I thought was way too hot. Looked like steam also. I quickly shut it down.
Can I pull the LU again without draining the brand new fill of 90W? Also, the two leads from the temp switch in the block are unhooked from the terminal, and I don't know where they are supposed to go. Not sure what to do next. I AM sure that I'm not starting her up again until I sort this out.
Any suggestions ??
Any suggestions ??
