Thor_Driver
Thread starter- Joined
- Jul 8, 2010
- 2
My motor is a 1997 model year s200txrv. It sat for over year and the fuel turned bad. I cleaned the tank, lines, filters and such and removed maybe two quarts of water with 40 gallons of fuel I had to repurpose.
Fresh fuel, 90 octane recreational gas, no ethanol added to the fuel tank. Motor started and stopped straight away. I tried a few squeezes on the primer bulb and fuel squirted out the air jet intake on the top carburetor. I thought that the floats were hung up and took it off to find it full of an opaque jell like b b size pellets. I removed the other two carburetors and found similar conditions so I rebuilt all three of them. I also cleaned the two fuel pumps.
I re-installed the carburetors today and the same thing on the top carburetor occured again. Fuel squirts out of the main jet air intake of the carburetor, the other two are fine.
With the carburetor off the motor, I can hold the carburetor upside down to seat the needles and push 20 psi of air from the compressor and no there is no leakage.
I am at a lost as to what causes this and would greatly appreciate any ideas to remedy the situation.
Thank you in advance for any help you can offer.
