If you've not changed (or know when it was changed) the impeller, I'd look at doing that and then confirming the system is cooling like it should. Make sure you've got a good charge on your batteries and things are shifting like they should.
I usually treat my first run out in the spring like a "shake down" run ... second time out is usually for family fun
