Salt water engine fail
jumpjets
I have been running a raw water cooled 5.7 merc in salt water for the last 5 years. I routinely inspect my manifolds and risers for excessive rust. I know I the risers, impeller, and thermostat area are critical rust areas, where else should I inspect for rust? When this engine eventually fails, I'd like to be able to anticipate how and where it will die.
Since I spend time out on the Atlantic, I want to replace the engine before I get marooned at sea.
If your flushing with fresh water it will last longer. That said, the manifolds are in most cases the first to go. Most get 5 to 7 years before they go
Ayuh,.... I hear the 5 to 7 year thing, 'n it makes sense,....
The block itself oughta last 20,.... I hear an iron intake manifold is good for 'bout half of that,....
jumpjets
Just to amplify, I perform a 5-10 minute fresh water flush before and after every trip. I run it on muffs before each outing to ensure its functioning. I run it after each outing just to flush.
The whole engine setup has 5 years of salt use. The manifolds look like the titanic ruins on the inside. I think I'll replace them with some GLM units.
Where should I get a new intake manifold at a decent price? Should I get a thermostat and housing as well? Water pump? Cylinder heads?
Many GLM units need to have the surfaces flattened. Check them real good with a straight edge before use
Cylinder heads should last as long as the block, I would use google and search for the part numbers for other items. Most the cost is all over the place
dingbat
Lived that scenario with my first boat. Gimbal bearings, manifolds, risers.....Never again. Sold it and went to outboards. Inboard diesel would be my other choice
indy440
I've seen the head bolts that are on the outside of the block under the manifolds rust right off and become impossible to turn also.
rick3452
I would go BARR rather than GLM, made in the USA But make sure you use only OEM Gaskets.....
