Bigjohn1
Thread starter- Joined
- Jul 19, 2005
- 170
Looking for those with trailer wiring experience. I have replaced my lights too many times (both incandescent and LED) after saltwater eventually trashed them. I am installing PVC guides on my trailer and will mount a new set of LED?s atop these guides where they never touch the water. I will install a new wiring harness as well but want to give some serious thought to where the ground point for the lights will be. With past light sets I have used (again both standard lights and LED?s) the ground point was directly under the light mounting area (EZ Loader trailer) screwed directly into the metal trailer frame. Specifically on grounding:
1. Should I be looking to ground the lights up at the trailer tongue where they won?t get exposed to saltwater?
2. Are there any light sets out there which I can mount atop my PVC guides which don?t require a separate ground wire? I currently have a set of el cheapo West Marine removable lights and those don?t have separate ground wires but they are not waterproof.
I?m tired of messing with trailer lights every year and want this set to last longer?.any ideas? I plan to use Ancor hot melt glue butt connectors and heat shrink tubing so this is the last set I install.
