Re: Sand/bead blasting
I purchased this sandblaster from Northern Tool about a month ago. This turned out to work like $#*%.<br />Northern_Blaster <br /><br />It constantly get clogged, even with the expensive media. I have taken it apart so many times that I could now do it in the dark. Now it just sits in the corner.<br /><br />One of my friends suggested this model. <br />Northern_BlasterII <br /><br />It only cost $20.00 and works great. The trick is to hold the trigger down with the hose out of the media, then insert the hose into the media with your other hand when blasting. If you do your blasting in a large cardboard box (outside as suggested), you can save most of the media for the recycle. I do have a sandblaster that produce 10cfm @ 125psi which also helps.
