Boomyal
- Joined
- Aug 16, 2003
- 12,072
Re: Sand Blasting
Lindy, I taped and sand blasted the outer face of my intermediate housing, just enough to get any loose stuff off. On the outdrive, I pulled off all of the little pieces and sand blasted them. Leave the forward facing part of the outdrive alone.
Sand the outdrive with 80 grit wet and dry, using water with dishsoap in it. Some places you'll go to bare metal, some places you won't.
Immediately flush everything off, give it a vinegar bath, then wash it with the amonia, dry it all thoroughly then hit the bare spots with zinc Chromate.
Then overprime and shoot your cover coat.
You can see the results in my pictures. They well endured the summer boating activities. This having to respray every year is due to inadequate prep and the wrong paint. Only in places that you drag thru the sand, should you have to repaint that often.
Lyndy said:Thank You Boomyal! If I am going to do this by hand, I know I will be doing some scraping. The vast amount of the corrosion is bubbling under the Black paint. I have scraped off the paint where corrosion is evident which comes off VERY easy leaving bare aluminum.
That bare aluminum still needs to be treated prior to Priming and Painting, doesn't it?
Where the corrosion is not apparent under the Black Paint, I intend to ruff it up ,prime it and paint it.
Am I heading in the right direction here with doing it by hand?
