Sand in lower unit !!!!!
michaud500
So I pulled the lower unit off my 1969 Mercury 500 and I have discovered sand everywhere,except the pump and impeller I think. My last cruise I bottomed out and messed up my prop. Could this be why there is sand in it?? Also where is the best place to get the right parts? I have been using Old Mercs, which I like. But would like and alternative.
The impeller was trash. Does this mean I should replace ALL the gaskets in the pump? I have only had the boat a little
while and am new to boating.
Thanks for your help!!!
carholme
Re: Sand in lower unit !!!!!
Well it sure would have sucked in some sand.
The 1969 is a model:
1500109 MERCURY 1969 50
Parts listing:
http://www.crowleymarine.com/mercury-outboard/437.cfm
For the cost of the gaskets, I would replace them and most of all, give the engine a good flushing. When the Lower unit is off for the impeller change, ensure that the long water tube is clear and adapt a water hose to the bottom end and let the water flow through the engine.
Gerry
michaud500
Thanks for the insight. To flush you mean some how hook up a hose to the tube that goes from the engine to the pump?
carholme
Yes from the bottom up into the engine.
Gerry
