1983 ercoa 21'
Thread starter- Joined
- Jan 12, 2014
- 632
Has anyone here tried sand blasting the crud off the pontoons? What was end result?
Glad to be here.
I have tried a high pressure washer,the works,acid,wire wheel,grinder with a sand paper type wheel has done the most good. I'm at wit's end with the build up on these rooms the blaster I contacted informed me of the rough texture blasting leaves behind he also said that primer holds very well to it and could paint.I'm. Thinking this is the way to go and forgo the endless battle of dulling toons.i bought this boat from 1st owner and from day one was left on the water so to can image the build up. Was wondering if anyone else has gone this direction and could share pros and cons?
Glad to be here.
Well everything I have heard scared me out of sandblasting the crud off I'm going to try a different route with different grits' of sandpaper on a belt sander starting with a heavy grit and finish with a lighter grit as I get closer to the aluminum. Now if this weather would ever warm up I'll get started
I have read alot of threads about removing this deposit that is left on the toons from being kept in the water it's whole life or at least the biggest part of it.
I have used a wire wheel on it in some small areas that took alot of time and the aluminum looks good under the unknown growth. I understand a belt sander leaving lines or groves in a round toon but my toon is a ercoa that has hex toons.
I have tried about everything I have read I'm down to the elbow grease that everyone talks about.
if there is something else I haven't read please share? I'm not sure what the growth is if it helps it came from Bella Vista lake in Arkansas. I'm pretty sure it's a shell lake meaning shell rock. Any helpful information is greatly appreciated
I'm currently looking into a product called por-15 to coat my goons with to stop further corrosion and add protection
