Sandblasting spark plugs???
SANDERDS
I pulled the spark plugs out of my Outboard. While they seemed to still be working fine, they do have some carbon build-up, so I was wondering what the best way was to clean it off. I have access to a sand blaster at work and could tune these baby's up in a few seconds. Does anyone know if this is a bad idea for some reason. I cleaned all the oil off with break cleaner, so I shouldn't contaminate the sandblaster.
david_r
Re: Sandblasting spark plugs???
i would do a de-carb and change the plugs. you can find the instructions in the "frequently asked questions" forum.
you can clean them like that if you have access....... in fact that would be the ultimate way to clean them.
i would also be very careful with the ceramic... since ob plugs are very heat sensitve....... also stay with the factory specified plugs.... usually champion on rudes and johnnys
jasper60103
I usually use brake cleaner and a wire brush.
SANDERDS
Thanks. I do plan to buy an install new plugs, but having a cleaned set in the tool box for back-up might be nice.
PS. I like the trailer on your post....kind of true.
jay mendoza
I have used a plug sand blaster (Harbor Freight), they do clean the plug, but remove the Cad plate off the metal and threads. You have to clean the threads when your done, and blow the plug out with compressed air to clear it of abrasive media. Any media in the threads will mess up the threads in the spark plug hole, so be careful. Due to the Cad plate being gone, put some anti-seize on the threads of the plug.
I once saw an SAE study done on the resistivity, and insulting properties of spark plugs that were new, used, and cleaned by several processes. The wire brush method had the poorest results due to metal being deposited from the brush on the ceramic insulator. Cleaning with solvent and bristle brush was a little better, and media blasting was a little better yet. Interestingly however, none of the cleaned plugs were very good compared with a new plug as far as insulative resistance. Amazingly, a used plug from a good running engine that was not fouled was better than a cleaned plug's insulative properties! They determined that the porous ceramic absorbed carbon when cleaned with solvents and degraded it's insulative properties. Media blasting removes the finish of the porcelean surface of the ceramic insulator, making it rougher and easier for solvents and carbon to penetrate.
This paper was probably written by an engineer working for Champion, as the obviouse point is that nothing beats a new spark plug when it comes to getting the best spark, and performance.
I have found that with a plug that is new, but fouled black due to a rich condition, if I just blow it dry, and correct the mixture problem, then run the plug in the engine under normal load for a while, it burns clean and takes on a nice light tan color.
I run my plugs until a light deposit begins to form on the insulator, or the center electrode just starts to erode. You save old used plugs that are no longer made, and blast them, but I always use new plugs if they are availlable, as they are only $2.79 each.
petryshyn
Ditto Jay...
Sand blasting is hard on the ceramic finish. Use "Chisel" or "Gasket Remover" and rub with a fine Stainless Steel brush. Rinse with "Carb Cleaner" and blow dry...IMO
tashasdaddy
i use carb cleaner, and air pressure, but best to replace.
SANDERDS
Thanks to all. Since they seemed to be working fine anyway, you all convinced me not to sandblast them. I may just take an emory cloth to them or scratch around a bith with a knife. Then I'll also just get some new ones. I've never had to change them to get my motors running, but I still thought a back-up plan would be good, so I'll keep the old ones just in case.
JB
Not many years ago it was standard practice to media blast plugs and there were many devices made that protected the portion of the plug that was not in the combustion chamber. I suppose there was some vulnerability of the ceramic, but do not recall any problems.
I usually decarbed my 2 strokes with water sprayed into the carb(s). That left the plugs squeaky clean and did zero damage. Then all I had to do was confirm gap or regap.
The only time I changed plugs was when the electrode had eroded to the point that it couldn't be regapped correctly. That was usually after many YEARS of good performance.
My opinion: Changing plug$ at the drop of a hat is wa$ted bux. . .like changing oil in a car every 1,000 miles.
