sphelps
- Joined
- Nov 16, 2011
- 11,500
I guess there isn't a specific formula .. I would think to much weight up front would be worse than to much toward the rear ..Plan on placing the battery's up front so maybe set the console a little further back from center ..
On new steering systems , are the cables already connected to the hub ? Or is that end flexible enough to get pushed through a pipe raceway like a conduit ...
i would really like to run it under the floor if I can ...
If I can push /pull it through say a 1" or 1-1/2" pipe up into the console that would be great .. I would like to run it straight down and straight back on the inside edge of the outside stringer . Then come up on the outer edge of the bilge pocket .. It will then have to loop around to line up with the front of the motor ..
