Say, outboard wrenches. Check this out.
wilkin250r
Re: Say, outboard wrenches. Check this out.
Add a note in there that, when checking for spark, the spark plug MUST be grounded to the block at all times, and you cannot leave the spark plug wires hanging freely. Otherwise, especially with Force CDI's, you could damage the packs.
jtexas
I've always assumed that the water pump is engaged during cranking - is that true and if so, I recommend a warning not to crank the engine without water to the inlets.<br /><br />May some other source on how to use a multimeter & what is voltage drop, etc. could be linked to your FAQ to keep down on the clutter.<br /><br />jtw
