SBC Bypass hose
Olds Eddie
When I installed my San Juan Engineering heat exchanger on my 5.7 SBC they required that a bypass hose be connected between the thermostat housing \ crossover on the manifold and the water pump. Since I don't run a heater, I would like to do away with this hose. Is this OK?
Laddies
Banned
Re: SBC Bypass hose
NO,The hose acts a bypass till the thermostat opens
Olds Eddie
Re: SBC Bypass hose
Wouldn't the engine coolant just warm up a little quicker?
trog100
Re: SBC Bypass hose
it wouldnt make a deal of difference to how long it takes for the engine to warm up.. not without a heater in line.. i think the idea is to stop too much back pressure being generated by the pump working against a full stop.. whether this is necessary or not i have no idea..<br /><br />trog100
rodbolt
Re: SBC Bypass hose
hello<br /> it prevents the water in the heads from boiling while waiting on the heat convection to open the t-stat and allows a more even heating of the water and metal parts. use it or not is up to you.<br /> some do it your selfers cant seem to get it right even with instructions?
Olds Eddie
Re: SBC Bypass hose
Thanks for the input. That makes since. I am not as familiar with the SBC as I am with Oldsmobile V8 engines. Olds thermostat housings have the bypass built in and so I have never had to contemplate this issue in the past. I had read some where that the bypass wasn't necessary, but usually if the instructions say to do something there is a reason. I am an ASE certified tech and self tought marine mechanic. Your never too old to learn something new if you keep an open mind.
