Re: Schematic Help!
You sure can, just get a 120 to 12 volt step down transformer from Radio Shack, couple it to a bridge rectifier, add some capacitors. That would get you to 12 volts. I don't know if you would need a regulator since house current is pretty stable anyway. Schematic and the others can probrably get you the values and other info for making your power supply. Or, you could just buy one already built from Radio Shack. Unless of course, you wanna shady it from old radio parts.
Just hook up the power supply in place of your battery and you should be good to go.
Good Luck!
