Score: Boat 1, Trailer 1, Me 1
rboat99
Re: Score: Boat 1, Trailer 1, Me 1
Thanks Red.<br /><br />By the way, you bring up a good point. Does anyone know what type of metal the bolt should be made of? To minimize the possibility of later corrosion I would like to put the same type of bolt back. Assuming that I can't just order a replacement bolt from the Johnny/Rude dealer.
rboat99
Wow, I can't believe I did it! I was ready to take this thing to the shop when the $50 bolt-out/screw-out set didn't move the broken bolt in my intake manifold. All it did was chew up 1/4" of the bolt before I stopped (taking it back to Sears tomorrow).<br /><br />So I called my uncle and he gave me a few words of encouragment, and a few more tips on how to use the old fashion easy-outs (had a set sitting on my shelf).<br /><br />When I got home from work I tried what I learned here plus what he told me and presto, the bolt backed out after my first try!<br /><br />What a relief. Now I just have to find replacement bolt. From the way the bolt shredded as I drilled it I think it may have been an aluminium bolt, would it be ok to replace it with a stainless steel bolt instead?
voodoo
the bolt will not be aluminum be wary of stainless it may react with the block..
rboat99
Does anyone know what these bolts are made of?
jim dozier
Your best bet is to replace it with the OEM bolt.
Dhadley
The OE bolts are stainless steel.
rboat99
OK, so I found a suitable SS bolt at Lowes, bolted the throttle bodys/carbs back on and headed to the river to test.<br /><br />Got past the No Wake and opened her up, she's running great now at WOT! No hesitation at all. Score: 1 for me<br /><br />Thanks to Dhadley, jimd, voodoo, redxfred, hooty, alumistar, rdav13, walker, stairliftofheaven, joe reeves, ob,rickdboat, and anyone else I may have missed.<br /><br />After replacing some parts I am still having charging problems, but I will continue that problem in another post.<br />Score: 1 for the boat<br /><br />Lastly, a bunk board fell off my trailer when I took the boat to the river to test. Score: 1 for the trailer ;)
