Screws loose and stripped
Status
Not open for further replies.
Thomv
On a recently used purchased of 29 foot Powerquest FX, I need some advise how to fix two of my display panels that are used to mount all of my guages and toggle switches. Both aluminum plates are mounted to the fiberglass console with#8 stainless steel flat head screws. The problem is that almost all of the screws that are screwed into the fiberglass console no longer grip into the fiberglass console which is only about 3/8 of an inch thick. All of the holes are oversized and I need to know what I need to do to make the srews have something to grab onto to hold both of these aluminum display panels to the fiberglass consoles. I was thinking of gluing down some plywood to the bottom inside of each console. Just open to any suggestions to fix this problem.
Silvertip
Honorary Supreme Mariner
Re: Screws loose and stripped
Go to any ACE hardware store and head for the little bins and drawers full of specialty hardware. Look for threaded inserts which look like some of these.
Thread Inserts for Metal, Wood and Plastic by E-ZLOK
ACE always has the type of brass insert second from the right in the link above. You can use #8 stainless pan head machine screws (not wood screws) with these. You screw these inserts into the panel fastening them firmly with epoxy so they don't come loose. Get the screws at ACE as well. At my store the inserts are 55 cents each.
JB
Double thread, closed
Status
