Sea king 7hp gas fittings
Titan1051
I am looking for info on this motor. Lt is made by Clinton engines, model K700 3107A, serial # 920301, type no 60 27370R.<br /><br />I need the year so I can try to find gas fittings. Fuel line connector (female). It looks like a Chrysler connection to me. <br /><br />I also need gas/oil mixture for this model. Any help is appreciated.
Laddies
Banned
Re: Sea king 7hp gas fittings
The fitting you need is avaliabe thru NAPA you will probably need to take your half with you to match it up the mix is 25 to 1
steelespike
It is possible a Chrysler fitting will work.As stated it may be available at NAPA.
steelespike
My info only goes to 72 and the K700 began production in 72.But Im pretty sure was made in at least 73 as well.
