I have (Ithink) '74 Clinton model #K7503107D Sereal #996393 Type # XTV52207. Am I right on maker and yr? Also what is fuel mixture, is it water cooled, and How do I check/change (if need to) the lower lube? I dont see a screw to check or fill it. I see one screw in the hole above prop in front and a nut/bolt on the back oppisite side (back). P.S. will this manuel work for this motor http://cgi.ebay.com/ebaymotors/Eska...8716759QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
"Keep them runnin"
"Keep them runnin"
