freddyray21
- Joined
- Jun 10, 2006
- 2,460
Re: Sea King
probably less a timing thing and more of a low speed adjustment on the carb.
The throttle stop screw on the side of the carburetor is the idle mixture screw. It affects the mixture by holding the throttle valve partly open without advancing the spark. If you don't believe it, try opening the carb throttle on one of your other motors, without advancing the spark. It will lean out, sneeze, and quit.
Thats one think I can do all day with my seagull, my anzani, and my J.A.P. seabee and they all have no way of advancing the spark when running.
The throttle stop screw is a throttle stop because it stops the throttle from dropping and will in no way change the fuel mixture. That's what you have a dirty great big mixture knob for, that is for changing the mixture, not the throttle stop screw and no I dont believe it.
I just hate it when I'm told what I can or can't do!
Now I'm going to lie down in a darkened room.
First off, you call this an Idle mixture screw and I said it has nothing to do with mixture, even your manual does not call it a mixture screw.
Second as you quoted I could not rev up one of my outboards without advancing the spark.
Well, what can i say, your post speaks for itself.
But unlike you I am not slagging off other peoples outboards.
