Well today I began pulling the flooring on the sea nymph. Had a little spare time today and figured it was time to start the project. Floor was shot which I already knew. Some of the foam was wet, some wasnt so far. I pulled most everything behind the windshield and in front of the splashwell. Nothing too concerning showed up besides one support was cracked at the tip. Also something i havent seen on the forums from other peoples tear downs was these aluminum plates what were below the wood on top of the cross supports. They were under where the front seats went. Not sure if these should go back in when the new flooring goes in or not. The front seats are pedestal seats with no holes needing drilled. I got lucky with this part of the foam. I could just grab it and pull it out. As always, pics...
The foam filling holes...
