You got the pumps in and tested out right?
Yes, I tested the bilge in the sink, did not test the aerator.
Thanks!I glued / screwed the seat backers onto the decking and drilled the pedestal holes before sealing.
Oh man nice work on the fit. :thumb:
I can't tell for sure but it looks like maybe the seat bases are going to be straddling the 2 pieces of decking or close to the seam. Either way that joint will have to be super strong.
Thanks Watermann! I knew before i even started the project thats how i wanted to do the foam. I saw other builds with foam that way on the forums and knew it was a good idea. Gets more foam in the boat and provides decking support. Little more work but worth it in the end.Hey nice job on the foam by the way, you'd be hard pressed to to do better.
IMG_20170710_223432754 by nick arend, on Flickr
IMG_20170711_215442088 by nick arend, on Flickr
IMG_20170711_215430538_HDR by nick arend, on Flickr
IMG_20170712_161955914 by nick arend, on Flickr
IMG_20170712_162012525 by nick arend, on FlickrYou mentioned Epoxy, what was the deciding factor for you in terms of choosing epoxy over poly?
