cptnmcluvin
Thread starter- Joined
- Jul 29, 2010
- 72
I wanted to provide a follow up for this thread.
http://forums.iboats.com/prop-questions-topics/sea-ray-br-210-prop-selection-problems-568994.html
This summer we upgraded the SeaRay BR 210 from a 3 blade 21 pitch prop to a 4 blade 20 pitch prop.
The results were successful. Hole shot and watersports towing were much improved.
The Merc 5.0 engine even sounds better with the 4 blade prop.
However, the 20 pitch prop is still a little too tall for optimal wakeboarding.
Again, the 20 pitch is much better for wakeboarding than the 21 pitch was.
Cruising rpms and mph were about the same.
We never drive much over 30 mph so the top end performance is not relevant for our use.
Which brings up the point that we never red line our boats and don't plan to.
I may be technically incorrect but the idea of red lining the boat to test a prop does not appeal to me.
When you buy car tires, do you drive 150 mph to determine if they work?
Yes, I realize the WOT performance test can help determine if a prop takes the motor out of normal rpm ranges.
Despite what everybody says I'll stick with the 0 to 30 mph test results.
