Sea ray sundeck 240 won’t rev passed 2000rpm
Easa
Hi, I have a sea ray sundeck 240 with a mercruiser 350 mag engine that won’t passed 2000 rpm under load, also while cruising at low speed rpm will dropped and engine will eventually die. I already ready replaced a few parts:
Fuel pump
Fuel injectors
Spark plugs
Ignition cap and rotor
Spark plug cables
TPS sensor
I attached a video of my boat even at full throttle it won’t passed 2k rpm
  • IMG_8525.mov
  • IMG_8528.mov
Fun Times
Sometimes when the engine doesn't seem to want to go past a certain RPM like that anywhere from say half to full throttle including no additional boat speed it turns out to be internal engine type issues.
Did this all of a sudden do this or was there some sort of service type job involved at any time and now the boat won't plane?
Easa
I just got the boat, so I don’t know if the previous owner did some sort of service. Engine runs smooth when not under load, I already checked engine compression and it’s good. Boat looks like it’s hasn’t being used for a while.
Fun Times
What year engine model are you working with?
Serial number?
If you happen to have an hour and a half of reading time, the following situation may help go over some potentials to consider...Turns out the valves needed adjusted here, http://clubsearay.com/index.php?threads/absolutely-frustrated-with-this-mercruiser-engine.112106/
Easa
Serial number?
I don’t have the engine serial number right now, but It’s a 2007 mercruiser 350 mag V8. Engine only have 146 hours. My guess is that this boat was abandoned for years.
Easa
I was thinking of replacing the ignition coil, do you guys thinks is a good idea?
Compression test was 115-120 psi on all pistons,
If your gauge is accurate then the motor is tired, should be closer to 150.
Check the timing as seen in the pic. Bring number 1 to TDC and then verify distributor location
Easa
Thank you! I’ll do another compression test with a different gauge. Engine run smooth just don’t rev passed 2k rpm
I’m thinking of replacing my coil? Do you think it can be the cause of my problem?
No
Very, very rare for a coil to go bad. Folks replace them all the time, wish I had stock in the coil Co I'd be rich
It's never the coil...ever
With only 40psi, your fuel pressure is low
With compression in the 115-120 range, the motor needs a rebuild
If your neutral safety switch is bad, motor won't rev when in gear
Time to start trouble shooting
