Sea Ray Top speed problem
neilmw
Noticed the other day that with the engine fully trimmed out there is hardly in increase in speed from when the engine is running at 3500 and increased to wot (4400) bow seems to lower but i am unable to trim out any further as it starts to cavitate. any ideas????
tommays
Re: Sea Ray Top speed problem
as a long time sailor i would be wondering how clean your bottom is<br /><br />a thin layer of slime will slow you down a lot a heavy enough one could keep you from even getting on plane<br /><br /><br />tommays
dutch135
Neil,<br />Is this something new that just happened? Or has it been like this the whole time you have had the boat?
neilmw
Must admit I have just recently noticed it, I put two coats of antifoul on before launching in April, did i waste my time painting do you think??
tommays
you did not waste your time <br /><br /> its and easy thing to check and far more common then you would believe <br /><br />if its clean look somewere else if not take a swim with a sotch brite pad ;) <br /><br /><br />marine life on boats bottoms is different all over the place even different in the southern and northern USA<br /><br />tommays
