Sea Trials, list the necessaries
simplydave
Aside from a towing company policy, what would be the run down for the first time launch? Gas, check, life jackets, check, coast guard package, check, vhf radio, check,
Any other suggestions?
JASinIL2006
Aside from the above, I'd include an experienced boater (if you are not) to take along and show you the ropes.
airshot
Cell phone...they can be more usefull than the VHF radio should a problem occur. And I would second the experienced boater idea..
Silvertip
You haven't mentioned a word about checking the very vessel that will be carrying you. Good battery, engine serviced and oil topped off, all gauges operational, bilge plug installed, do bilge pump(s) work, do the engine bay blowers work, general visual inspection of engine bay, boat exterior and trailer. Trailer tires properly inflated, do the brakes work (if equipped) and are all lights operational. Before you leave the dock, check instruments for proper readings. If one is not operational or reading abnormally, don't leave the dock until/unless you verify why. If the seller says it's a bad gauge, it likely is not and you need to verify what's wrong. If you have little to zero mechanical/electrical skills, then basic tools are of no use to you and a Tow Policy becomes the safety net. Otherwise having some basic tools can save you a tow and save what may be a nice day on the water.
drrpm
There's a big difference between taking out a runabout on a small lake and heading for the deep blue sea on a big multi engine cruiser. Make sure there's enough fuel for the trip, everything works, everyone has a PFD and add on from there depending on location, vessel, etc. Having a cell phone and letting someone know of your plans are also good ideas.
You should have about 1/3 of your fuel in reserve. So 1/3 out, 1/3 back, 1/3 in reserve. Weather, wind, waves can all conspire to slow your progress, causing you to burn more fuel. Cel phones work only near shore cell towers. Off shore or out in a big lake, they may not work.
I like the women suggestion as well. At least you can die happy....
