Seafoam
redneck joe
Big subject with lots of opinions. I use it every newbost, double the recipe on the can. Others will tell youtnat you are wasting your money.
Faztbullet
What is the best way to use seafoam
Follow instructions on can....
and doest it work for cleaning carbs?
It will keep clean carbs clean and removes some varnish that may cause idling problem. DO NOT USE it to try and unstop a carb as the cylinders fed by that carb are not receiving lubrication..
Texasmark
The contents are Naptha, Light mineral oil, and Alcohol; quantites unknown. Google the MSDS (Material Safety Data Sheet.....tells all about what's in a product) The oil is in there deliberately for 2 stroke engine lubrication. How much I don't know but 50:1 premix isn't much oil either.
I used it religiously in my 2002 90 triple looper, added to my regular (unleaded) grade gas/gas+10% ethanol blend, or premix, depending on what I was running at the time. In 2012 I decided to have a look at the carbs and possibly put in kits if needed. Opened it up, had a good look-see and put it all back together with all the existing parts.....been running every since. Obviously there wasn't anything to fix and I was careful with the gaskets, and inspected the needle valve which had no groove and was still pliable, checked the float binding and ensured that no foreign objects (fuel line) was present. I did have fuel line problems but that was another time and another story. The OEM line between the tank and engine disintegrated leaving chunks of it in the fuel inlet.
I knew not of the product before joining this forum. Lot of chatter about "Decarbing" and Sea Foam and all that "rot". Figured it wouldn't hurt anything......
My boat didn't see much use. I'd go out every couple of months and run for about an hour and put it back up. I did run it however. Had 2 speeds: Off and WOT. Gas would be as old as a year. Never had a problem.
Am I sold on the stuff?????? Naw. Just a pipe dream. Grin.
hotrod53
I used Seafoam in the fuel tank of my 2007 Toyota Camry 4 cylinder and it instantly started burning a quart of oil every 1200 miles. I had to get the engine rebuilt as the oil return holes in the pistons clogged up with gunk. Did Seafoam cause it, I think so, but Camrys are known for the an issue. It may have just expedited the issue. If nothing else, it shows that Seafoam does something.
Have I used it in my '77 Merc 500, yes and have had no issues. I currently use an enzyme treatment and have had no issues.
