Any help you can give would be great! Thank you in advance. I have a 1980 Clinton Seaking. It idols pretty well but when I took it out it spit and sputtered. I thought I cleaned the carb really well. Ideas?
Also, any ideas where I can get a rebuld kit for the carb?
How do I i.d. the carb and find part number?
I made a new gasket to go between the carb and the engine body because I thought it might be sucking air. I pulled and checked all the jets I could find. I set the float as best I could. I ran the bowl scew in all the way and backed it out 1.5 turns; same with the mixture screw. Still, when I put it in gear and try to run it up, it dies or almost dies.
Please help/
Please help/
