Seal bottom
gbb
I just got a project 13' Whaler. I need alot of info. The bottom needs a lot of work. Can I sand it down to the fiberglass and just put a coat of epoxy resin on it? I want to just paint the boat, it will be trailered. I was thinking about painting on a barrier coat also, what would be the best way to go about repairing this?
ezmobee
Re: Seal bottom
What's the problem with the glass on the bottom? I don't think I'd add just epoxy resin to the hull. The constant flexing from use would cause it to fail pretty quickly I'd think without some fiberglass being added to it.
gbb
Re: Seal bottom
Spider cracks everywhere and some small pieces are exposed. I was just going to sand it down and patch, but didn't know how to reseal the bottom.
Any info on this would be great.
Yacht Dr.
Re: Seal bottom
Inerprotect 2000....
Shave and wear a good resporator !!..
YD.
PS. before IP2000 we had to use epoxy for barrior coatings..but the windows for recoat is hard to use it.. IP2000 has 2 weeks for hot coating itself :) good stuff but Nasty smellin' ..
NSBCraig
Re: Seal bottom
Yeah just use a barrier coat then if you want some bottom paint, but the barrier will seal it up like you want.
