stealthdrummer
- Joined
- Mar 7, 2010
- 95
Are seal kits available for a 1978 Merc dual ram power trim setup?
They used to be avail. Check Dougrussell.com or crowleymarine.com. If unavailable, call a dealer and see if he has one under a ton of dust on his shelf.
BTW- the teflon piston seal requires a special tool to install the piston back into the cylinder liner. The balance of the Orings are easy to install. What part is leaking?
Have you bled the trim rams? If not, this is the time. The resevoir is self bleeding. You just need to keep it full. The trim rams each have two bleed screws, that need to be opened in the proper position and the air let out.
I was unabel to see the picture, so I am working blind...
Crowleymarine.com shows instock seal kits for a 1978 merc 115, will ship immediately, for $51.47.
The exploded parts diaghrams also shows bleed screws. What HP motor do you have? Are you sure it is 1978? The PDF from Thumb is for a Mercruiser PTT sytem.
