sealant on gasket above and below wear plate
zeberus
do you use a sealant on the gaskets above and below the wear plate in the water pump on a alpha one drive ?
is the torque value of 69 - 90 in lbs correct
thanks
can't seem to find this info
Chris1956
Honorary Supreme Mariner
Re: sealant on gasket above and below wear plate
On my Alpha-1 Gen I, I never used any sealants. I used some grease on the orings. I also tightened the water pump cover nuts until they were snug, but never torqued them.
zeberus
thanks
manual says to use sealant on gasket under base, but nothing about the ones on both sides of the wear plate.
guess i,ll leave them dry.
