Wow! Talk about "Not" user friendly. I laid a bead along the underside of the rub rail & then with a wet finger smoothed it out. Then went to the other side to do the same, well, when I went back to the first section I did it was all running down the side of the boat:facepalm:. Guess I used way too much. I just hope this stuff is as good as I've been reading here. After looking at the seal along the rail I did notice that someone had tried to re-seal it at one time, I'm guessing this is where my leak is now. I dug out as much of the old silicone as I could (real PITA), & put a nice seal with the 5200. I ended up sealing everything on the transom as I could find just to make sure. I have very high hope's that this will be the cure I've been looking for. I really did not expect it to be so loose & runny though, I ended up with it everywhere, hands, arms, shirt, pants,etc... (OK, so I had a few beers & it was getting dark). Just wanted to up-date my leak search. Should be splashing it later today or first thing tomorrow.
