Sealing Bellows Volvo 270
Jim Marshall
I am installing new bellows on my '74 Volvo 270 outdrive. I cleaned up the exhaust transom connection (which showed some corrosion) and primed it ready to go. I noticed that there is a groove in the metal and a corresponding ridge on the bellows.
Should I apply a sealant when installing the bellows?
Thanks again,
Jim
zbnutcase
Re: Sealing Bellows Volvo 270
Yes on the u-joint bellows, not needed on the exhaust bellows
Robj
On my 290 I don't use adhesive for neither the drive or exhaust bellows. Really it is the clamping pressure that seals it. Never had any troubles. But regardless, you definitely don't need sealer for the exhaust since it is wet anyways.
Have a great day
Rob.
Jim Marshall
What kind of sealant would you recommend? Silicone, Urethane, Form-a-gasket?
Jim
Don S
Nothing. Volvo doesn't recommend using any kind of sealer on the bellows.
adeneo
As stated above, it's not recommended to use sealer on the bellows.
A little marine grease can be used and will help to seal, but make sure the bellows don't slip.
