PiratePast40
- Joined
- Mar 21, 2009
- 1,734
Re: Sealing deck
Check the local yellow pages for suppliers and call around to see where you can buy supplies. You might be surprised at what you find. Some CarQuest stores also have a paint supply store that has quite a bit of glassing supplies. Again, just keep calling around and asking. Do yourself a favor and keep reading threads here and checking web sites like US Composites for techniques.
You should be buying boxes of the plastic spatulas and might even look for a "bubble buster" roller for smoothing the surfaces and moving the bubbles out. One big issue to keep in mind about the bubbles left in the surface: Those bubbles are attached to nothing so they compromise the structure and leave areas for water to sit. You'll need to grind those out. It's really discouraging to have to go back and grind out your own work. Plus you have the insult of needing to clean up afterwards - believe me - I know :redface:.
Keep practicing but by all means keep reading. You seem to be moving forward pretty well.
