Sealing nylon?
DianneB
I made a temporary boat top from nylon and I need to waterproof it, not "water resistant" but waterPROOF.
I have used paraffin and white gas to waterproof canvas but don't know if it works on nylon....
I tried silicon and just about drown in a thunderstorm this weekend! :eek:
rbh
Re: Sealing nylon?
My thoughts are that using nylon may be the issue, great for pup tents but not for boats, you may be better off with tent canvas.
DianneB
Re: Sealing nylon?
I have Sunbrella-Plus but the boat will be rearranged next winter and I didn't want to use expensive fabric for only one season and then throw it away.
rbh
Re: Sealing nylon?
The only thing that I can think of if your using rip stop nylon is it has to be piano wire tight, and try scotch gaurd.
DianneB
Re: Sealing nylon?
It IS rip-stop nylon and it IS 'piano wire tight' when it is dry. The MAJOR problem is when it gets damp, it sags terribly.
KRH1326
Re: Sealing nylon?
I used a cheap home depot blue tarp for one season.
I cut it to fit, had wife double the edges over and sew it. I put the snaps in it to match what I had on the boat.
Good that I only needed it for one season, because that is all it lasted.
It was a basic ' mooring cover' not a complicated cabin set up, but it might work.
