shovelhead82
Thread starter- Joined
- Jun 28, 2010
- 12
I have a 1970 Sears 5hp that was sitting for maybe 20 years, I rebuilt the carb WITHOUT parts, changed the gear oil and tested her out with my boy on the reservoir after running in a barrel...it was a less than stellar trip as the motor would run for a few minutes, then die, start again, die ect. I hobbled home and with help from posts here got some carb parts. Rebuilt the carb again and I believe my problem might be solved altho I only ran it in a barrel so far.
My question to guys who know this motor is my old inlet needle had a spring attached to the top, the new one has a bent wire clip which really can not be used from what I can see. After fooling around with it, I installed the new needle without the wire clip, it started up and ran better than ever as I stated above but I wonder if this will cause problems. I have an original manual and it clearly shows the needle with the spring like my original. The new needle will not accept a spring unless maybe modified. I'm planning another test this wkd so I thought I'd toss this around with knowledgeable types!
Thanks, Art
Thanks, Art
