sears 3.5 hp carburator bowl leak
jakoolin
Hello everyone, I have an sears 3.5 hp engine serial # 217-58560. My question is whenever I put in gas on this there is a leak on this screw see attached photo. I don't know if this is something needed or can I just buy a regular screw and plug this thing up. Thanks
brim_buster
Re: sears 3.5 hp carburator bowl leak
thats a 72 made by Eska and it looks like a drain plug. you dont need it, just lets you drain the bowl without removing the high speed mixture screw which is the one in the center.
jakoolin
I'm a newbee on this. Do I have to take it all apart and plug it? If so what can you suggest as replacement plug. thnx
robert graham
That float bowl drain screw probably should have a washer or O-ring to seal it when it's tightened....
brim_buster
The manual made it look like 2 pcs. the one on the outside mates with one on the inside. you can remove the outside piece and maybe put a replacement screw in there I guess.
jakoolin
Brim_buster
By any chance you have a digital copy of that manual that you could share with me so I have a better understanding of this motor?
brim_buster
yep send me a private message with your email and I will send it:joyous:
could i get that manual too? just got one of these motors, funny thing is my carb just has a solid screw in the bottom not all that other stuff
