Sears / elgin 1957 12HP model: 571.58931
Status
Not open for further replies.
chosos
i need the part number or a link to the plastic pinion gear for the pull starter that engages the flywheel. mine just cracked and i cant seem to source one on the net.
thanks.
steelespike
Re: Sears / elgin 1957 12HP model: 571.58931
The motor is a West Bend,Became Chrysler in 65.The recoil starter appears similar on the West Bend model and Chryslers to 73.And may share parts from the 9,9 and 15 Force motors.There may be some differences but perhaps adaptable.The Force pinion is a common problem.
Tom @ Buzzard Bluff
If it's the same plastic pinion as the later Chrysler models you are SOL! I just recently read of a Chrysler collector who refuses to use the pullstarter on his restored motors lest he break the NLA pinion drive gear. He removes the hood and uses a rope on the emergency start sheave atop the flywheel.
F_R
Indeed, they are getting to be rare and endangered.
chosos
does anyone have a part number to a replacement? I am not having any luck searching using the words force and pinion.
F_R
1959 (571-58801) is part number 901674-2 (West Bend/Elgin part number) Probably changed under Chrysler/Force.
6hp Chrysler part number is 40674-2
That's all I know.
chosos
thanks, now the problem is that i just cant seem to find anyone with this thing in stock. i'd even take a used one at this point.
looks like:
901674-1
901674-2
40674-2
40674-4
are the part numbers for the bendix pull start gear that i need. ive emailed a few places but im not having much luck.
F_R
Yeah, we know. Rare and endangered species.
Tom @ Buzzard Bluff
IIRC I got one for a 6 hp @ 4-5 years ago from Franz Marine. It's be worth a call to see if he has one---new OR used. 1-816-966-8085
chosos
Franzmarine has one. $25.56 part # 901764
thanks everyone.
it looks like 901764 is 11 tooth and 40674 is 13 tooth
GULF VET
You could try www.american outboard.com
its american outboard motors & salvage
it looks like they have everything you could want or need.
M
mrcrabs
Guest
your link is bad Gulf Vet, and thank you for serving our country, I hope every thing is going well for you.
F_R
This thread is nearly a year old
M
mrcrabs
Guest
asset.php
M
mrcrabs
Guest
I think Iboats should let some of the old threads come up that are useful, it helps keep them easy to google up,
Scottso
I've had good luck looking on ebay for parts, and saw a nylon starting gear there. I'm still trying to find the remote control shifter arm bracket. for my 1957 12 hp.
GA_Boater
Please read the Help Tip on top of the page. This thread is over 5 years old.
Please start a new topic if you are looking for help. Members seldom look at the old ones.
Ej0987
I just recently got a eglin 12 HP and it not getting any fire to the plugs I cleaned and check the points and still nothing. Now what do I do
jbcurt00
Do as previously suggested:
Only now its been another 18months....
Start a topic about YOUR Elgin EJ...
Closed
Status
