Re: Sears Gamefisher 5hp -- 217.586611
have you done a spark and compression test on the unit before sending it to the graveyard? based on your numbers you do have a 1984. i don't know of any leads on a new power head. if you do want to remove the power head here it goes, unbolt and remove cylinder shroud, flywheel,magneto,cylinder head,reed valve and covers.remove connecting rod cap and push the rod and piston unit out through top of cylinder the crankshaft can be removed from all models after removing shroud base."note on av520 and av600 models with plain rod bearing, lock tab must be bent away from connecting rod screws before loosening. on other models make certain that the bearing needles are not lost in the crankcase on all models it may be necessary to remove ridge from top of cylinder before pushing piston and connecting rod assembly out". hope that helps you, good luck i just love turning a wrench and making something run again.
