Seat Foam
pocket aces
Needing to replace the seat foam. I can get High Density foam from Joann's Fabrics and use a 50% off coupon. It is firm but not as firm as some foam I have felt. What size for the bottom 3" and 2" for the back. Is this correct?
tfret
Re: Seat Foam
Just pull out what is already in there and measure it. I have seen guys get a free sofa or couch off craigslist and salvage the foam from it for the same purpose. You can use a filet knife to slice it down to whatever dimension you need. Just an idea...
Woodonglass
Re: Seat Foam
"Donor Couch" foam is usually not High Density foam so if that's important then you should get the High Density stuff. I used the Donor couch stuff and it was fine for me in a 4" thickness but others may like a firmer cushion.
