Seawater Pump include Impeller kit? 1998 OMC/VOLVO 5.0
BeerRanger
I am going to replace my seawater pump as it is leaking water from what seems to behind the pully and not just the gasket so thinking a bad bearing or seal. I traced the part number once I figured out my motor fell under the OMC umbrella. Does anyone know if the Seawater Pump Assembly #3857794 includes the impeller kit? The diagram seems to indicate it includes all the parts, but little description is available on any of the online stores I have found. Just hoping to get all need parts in one order.
Thanks!
1999 Four Winns Horizon 5.0GL/Volvo Penta SX.
Levinz11
Re: Seawater Pump include Impeller kit? 1998 OMC/VOLVO 5.0
Dunno...but damn that's an expensive bugger. Better order the impeller, too. You'll need it in a year or two anyhow.
wrench 3
Can you not get a repair kit for your pump?
BeerRanger
Thanks for the responses, and also good point on ordering an impeller kit anyway to have on hand for the next one.
Haven't found a rebuild kit for this particular pump and read some experiences of a few that have sourced the parts and replaced the seals only to have them fail after a few hours on the water. I'm figuring after 13 years and 300+ hours it'll make me feel better knowing there is a new pump in there.
Thanks again, this is such a great resource.
rpengr
For future readers of this post, I have seen people list the bearing as SKF# 6006-2RS1 or 6006-2RSC3
The SST version of this bearing is SKF# SS6006-2RS I don't know if Volvo used a Stainless Bearing or not, but it makes sense to me.
