I have a 1986 Sea Ray Seville 19 cuddy with a OMC 3.0L/Cobra that is in top shape and served me well this season. I did have a concern with the prop, though. First let me assure you the engine is fully tuned. It has a Pertonix coil and ignition, MagStar plug wires and new fuel filters among a ton of other normal maintenance work I've done. Here's the deal:
At WOT (roughly trimmed, on glass-smooth water, just me and 1/2 tank of fuel), the boat climbs steadily to 32MPH @ 3800RPM. With a bit more finessing the trim, it moves to 33MPH @ 4000RPM.
I'm satisfied with the time it takes to plane; I'm no speed racer, and I normally cruise at 3200-3500RPM (25-27MPH or so), but here's the catch-
I know the OMC 3.0L should rev to 4400-4600RPM, but my throttle is maxed at the control and the carb linkage cannot go any further. The engine sounds rougher than I think it should, but has worked fine this way. The prop is a Vortex MI aluminum, 13.25x17.
Would switching to a different prop (SS/4-blade/different/pitch/etc) do anything to move me closer to the WOT RPM or give me a quicker holeshot? Would switching give me one or the other, but not both?
Do I have a good combination already and should be happy?
