This thread is a sequel to my (motor rebuild questions) thread. I have a 2003 90 elpto that melted/fused the rings on #2. I have no history on the motor because I bought it knowing it was bad. At my first look, I have been concerned with the stuck/burnt rings on #2. The other rings were fine. Today I took the block to my machine shop and he pointed out minor marring on the other two cylinders. I went home and sure enough there is early signs of a problem on the remaining two pistons. I was leaning towards a root cause of #2 running lean but now I am wondering since the other two cylinders appear to be in early stages of also failing. There seems to me an excessive amount of carbon build up on all cylinders. Of course, I am going to rebuild all 3 carbs and make sure oil pump is working. I am looking for ideas on what else to check. I am now for sure buying 3 pistons and possibly paying to bore 3 cylinders (shop is going to try to hone first) so with all the money spent, I really need to do my best to figure out the root cause. Kinna tough with no history.. Some pics are attached. Any ideas are greatly appreciated….. Rick
This is the carbon build up on all 3 cylinders.
This is the marring on all 3 cylinders.
This is crud found around cylinders. It is not corrosion. It falls off with nylon brush...But it is there from something
This is what started it all. It has been very hot and melted the rings.
Thanks again, Rick
Thanks again, Rick
