seems timings a big issue
baileys
trying to find out about timing on my 50hp seahorse but replies are sparse so ordered a manual but wont be here for aleast 2 weeks and the seasons nearly over i aslo ordered a ignition coil from the boat shop over aweek ago and thats not here yet but how can you tell if the timings out if the ignition coil is faulty can any one help ?
Joe Reeves
Re: seems timings a big issue
What year is that Johnson outboard? If it's a two cylinder model, you can simply change the coil leads that connect between the powerpack and the coils to check the coils. After switching the leads, if the pack that didn't have spark now does have spark, then obviously the coil is okay.<br /><br />To check the timing, you would first need to know what the full spark advance timing is for your engine. Do a search on this website forum for 4°. You can make the degree ° mark by holding down the ALT key and typing in 0176 on your numeric keypad.
baileys
thanks joe but no numeric keypad on my lap top but there is on the home computer but my darling wifes on ebay so will try later
Joe Reeves
To save you the search.....<br /><br />(Timing At Cranking Speed 4°)<br />(J. Reeves)<br />The full spark advance can be adjusted without have the engine running at near full throttle as follows. <br /><br />To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary). <br /><br />Rig a spark tester and have the gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for. <br /><br />I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°. <br /><br />If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place. <br /><br />No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting. <br /><br />Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes.
baileys
thanks for the info joe will let u know what happens when it happens as we say down eeerr bay cheers bud
