SEI 116 outdrive lube 2010
Stanp1
I have a 1 yr old SEI 116, which is a basic Alpha 1 Gen 2 outdrive. I've put close to 40hrs on this outdrive since May. When I changed the gear lube, the old lube came out Black. I put the recommended green high performance gear lube in it before the season. Is this black color normal with 40hrs of use?
This is a conversion kit for an OMC cobra. No problems with the outdrive so far.
Pete104
Re: SEI 116 outdrive lube 2010
Yes normal. What gear ratio? Others have had complaints about certain ratio's. Just curious what you have. Just use the hi perf & you'll be fine!
Stanp1
I got the SEI in a 1:81 ratio. It's attached to a 4.3LX setup. (converted the 2bbl to a 4bbl weber from a merc 1996)
It's a different ratio than the original OMC 1:64 ratio. It actually runs better on my rig. I'm getting 4900rpm at wot with a 15x15 prop. I am considering moving up to a 14.5x17 prop to see if I can get more speed on the top end. But, when the boat is fully loaded, fuel, gear and 4 guys, she gets on plane with the 15x15 prop.So, I will leave it for now.
Thanks for the reply. I feel better.
Fordiesel69
This is a very good thing. This means the fluid has held up and is well used. It should come out dark like you are seeing. A creame green, or swirl is bad.
