- Joined
- Mar 8, 2009
- 44,437
Try to do in short
I short preload is 18 inch pounds
Replacing A1 drive with new SEI 106. Boat has a land and sea 12 inch stern jack which uses a special yoke and not the standard drive shaft. So the drive shaft is removed from new SEI drive to replace U joint.
Removed gear and bearing assembly. Switched out U joint, lube up bearings, tighten nut just barely touching, no torque applied yet and I see 18 inch lb.
Call Tech at SEI and verify SEI is done same as Alpha
So now looks like brand new drive bearings were to tight from factory. Before I try to separate bearings from drive gear I'm checking to see if I should do something else first
@muc , @dubs283 , @Fun Times
