Seized Mercury 50hp thunderbolt red band
briaineo
Have a question about a Mercury 50hp I picked up, was advertised as for parts or repair, the wiring is in excellent condition and overall was much better than I expected before collection, 3 cylinder.
With the plugs out and looking into the plug holes what should I see? Cylinder No. 1 is very far back (maybe 3 inches) and No. 2 about 1 inch back and Cylinder 3 maybe 1/4 ways back.
Does this sound correct? Or should all the pistons be evenly spaced from each other? Hoping a piston rod is not bent or broken.
At the moment I have penetrating oil in the cylinders and will remove the lower unit tonight.
Chinewalker
For clarity's sake, what is your serial number? To my knowledge, the Thunderbolt trademark was no longer in use when they went to a 3-cylinder 50hp. True "red band" 50s were built in the late 1960s and early 1970s and were 4-cylinder models.
As for being seized, are you sure it's in the powerhead? More than a few times, I've dropped a lower unit off to find the powerhead miraculously freed up!
Not all the pistons end up at the top of the cylinder at the same time !!!!!
